Programmable Devices
21615 Discussions
Cyclone 4 GX - Transceiver - EPCS-pins cannot be used?
we have a prototype board where we want to use REFCLK4 (Pin L10, F27-package) as reference-clock for a transciever. Now it turned out that we cannot access the EPCS-pins anymore when we use a data-rate of 2.97Gb/s (which we require).
Is there any way to make Quartus allow the usage of the EPCS pins, so that we can make at least some tests with our prototype-boards?
Thanks in advance,
Thomas
Try putting the toggle rate on those signals to zero
http://www.altera.com/support/kdb/solutions/rd05052003_3407.html
The Tcl constraint is
set_instance_assignment -name IO_MAXIMUM_TOGGLE_RATE "0 MHz" -to $port
where $port is the name of an EPCS pin.
Cheers,
Dave
Hi Dave,
thank you for your suggestion. We knew this trick already and tried it, but it did not work. I think it only works for regular LVDS-pins, not for transceivers. (I have the design not here in the moment, so I cannot double-check again. We are using QII 11.1sp2, maybe another version would do?)
Thomas
How are you interfacing to the EPCS pins?
Have you tried specifying them as "Use as regular I/O", and then setting the toggle constraint?
Cheers,
Dave
Yes, this is the way we did it.
The only way we can get the design compiled is by setting the respective 3 configuration-pins to "Compiler configured". (DCLK is not restricted, only MISO/MOSI/CS.)
Thomas
File a Service Request directly with Altera and see if they have a suggestion.
If they do come up with something that works, please post the solution here for others to see.
Cheers,
Dave
