21607 Discussions
Cyclone III AS programming with EPCS128
Dear Sir,
I have designed the board with EP3C120F484 cyclone III. In this board i have used EPCS128 Flash.
I am using AS Configuration.
But when i started the configuration. The configuration get failed at once.
Please provide the remedy for this fault.
try checking this doc and see if there is any issue you can detect on your board:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an523.pdf
What are the configuration modes you have?
Do you have JTAG?
Did you try program the SOF file through the JTAG?
If SOF programming is working, this means the JTAG is working. You may then try the JIC file programming.
What is the error message you see?
