21615 Discussions
Cyclone IV GX Transceiver Starter Board
hi
I have a question about this board. I want to kown which pin is the clock pin? In the Cyclone IV GX Transceiver Starter Board
Reference Manual, I just find three differental clocks. When I use it to run a simple program ,I need a clk (not differental clock). Who can help me?:o
Everything is OK with differential clock. Declare Your clock input as LVDS signal and assign both signals to corresponding FPGA pins.
--- Quote Start ---
--- Quote End ---
Thank you for you help. My problem has been solved.:)
