21615 Discussions
"make vendor_hwselect" probelm
Hi
I need help
when I want set Makefile according to DEO hardware setting,and the command is
"sudo make vendor_hwselect SYSPTF=/usr/local/src/DE0.ptf"
the errors occurred
make ARCH=nios2nommu -C vendors vendor_hwselect
make[1]: Entering directory `/usr/local/src/uClinux-dist/vendors'
make -C /usr/local/src/uClinux-dist/vendors/Altera/nios2nommu dir_v=/usr/local/src/uClinux-dist/vendors/Altera/nios2nommu -f /usr/local/src/uClinux-dist/vendors/vendors-common.mak vendor_hwselect
make[2]: Entering directory `/usr/local/src/uClinux-dist/vendors/Altera/nios2nommu'
[ -d /usr/local/src/uClinux-dist/romfs/$i ] || mkdir -p /usr/local/src/uClinux-dist/romfs
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- CFLAGS_KERNEL="" AFLAGS_KERNEL="" -C /usr/local/src/uClinux-dist/linux-2.6.x hwselect
/bin/sh: nios2-linux-uclibc-gcc: not found
make[3]: nios2-linux-uclibc-gcc: Command not found
make[3]: Entering directory `/usr/local/src/uClinux-dist/linux-2.6.x'
make[4]: nios2-linux-uclibc-gcc: Command not found
scripts/kconfig/conf --silentoldconfig Kconfig
arch/nios2nommu/Kconfig:5: invalid statement
make[5]: *** [silentoldconfig] Error 1
make[4]: *** [silentoldconfig] Error 2
RUNNING hwselect
Can't locate PTF/SystemPTF.pm in @INC (@INC contains: /arch/nios2nommu/scripts /etc/perl /usr/local/lib/perl/5.10.1 /usr/local/share/perl/5.10.1 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.10 /usr/share/perl/5.10 /usr/local/lib/site_perl .) at /usr/local/src/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/hwselect.pl line 8.
BEGIN failed--compilation aborted at /usr/local/src/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/hwselect.pl line 8.
make[3]: *** [hwselect] Error 2
make[3]: Leaving directory `/usr/local/src/uClinux-dist/linux-2.6.x'
make[2]: *** [vendor_hwselect] Error 2
make[2]: Leaving directory `/usr/local/src/uClinux-dist/vendors/Altera/nios2nommu'
make[1]: *** [vendor_hwselect] Error 2
make[1]: Leaving directory `/usr/local/src/uClinux-dist/vendors'
make: *** [vendor_hwselect] Error 2
My environment is: ubuntu
I can get the information
Reading specs from /opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/specs
Configured with: /root/buildroot/toolchain_build_nios2/gcc-3.4.6/configure --prefix=/opt/nios2 --build=i386-pc-linux-gnu --host=i386-pc-linux-gnu --target=nios2-linux-uclibc --enable-languages=c,c++ --disable-__cxa_atexit --enable-target-optspace --with-gnu-ld --disable-shared --disable-nls --enable-threads --enable-multilib
Thread model: posix
gcc version 3.4.6
Therefor it seems that the cross compiler is installed correctly
And
I setting the file in ~/.bash_profile
********************************# .bash_profile# Get the aliases and functions
if [ -f ~/.bashrc ]; then
. ~/.bashrc
fi# User specific environment and startup programs
PATH=$PATH:$HOME/bin:/opt/nios2/bin
export PATH
unset USERNAME
It seems like OK
I also do "make menuconfig"
vendor:Altera
Altera Product:nios2nommu
kernel version:linux-2.6.x
Libc Version:None
Default all setting
I only do not success that is "gunzip -c uClinux-dist-20070130-nios2-02.diff.gz | patch -p0"
it gives me the information
raul232641@ubuntu:/usr/local/src/uClinux-dist$ sudo gunzip -c uClinux-dist-20070130-nios2-02.diff.gz | patch -p0
patching file vendors/Altera/nios2nommu/config.arch
Hunk# 1 succeeded at 23 with fuzz 2 (offset 1 line).
Hunk# 2 succeeded at 36 (offset 1 line).
Hunk# 3 succeeded at 83 (offset 1 line).
Hunk# 4 succeeded at 91 (offset 1 line).
Hunk# 5 succeeded at 99 (offset 1 line).
Hunk# 6 succeeded at 117 (offset 1 line).
patch: **** Can't rename file vendors/Altera/nios2nommu/config.arch to vendors/Altera/nios2nommu/config.arch.orig : Permission denied
But I think that it is not a big deal
thank you~waste your time to see the so long thread
problem is here:
You can use the following commands to solve this problem quickly:
--- Quote Start ---
cd linux-2.6
git checkout test-nios2 -f
--- Quote End ---
--- Quote Start ---
cd uClinux-dist
--- Quote End ---
you can also find further info here:
http://www.alteraforum.com/forum/showthread.php?t=23549
Thank you very much .
It work.
