21611 Discussions
Cyclone IV Jrunner configuration fails with Remote-Update image
I am trying to do an initial program-load of a Cyclone IV using JRunner. There is an attached EPCS64 that has NOT been programmed.
I can successfully use Jrunner to program an image that does not contain remote update.
When I use Jrunner to load an image containing remote update, the CONFIG_DONE pin goes high for 12mS then goes back low.
If I load the non-remote-update image first and then the remote-update image, the load is successful.
Any ideas? I really don't want to load two images!!!
