21600 Discussions
Cyclone IV Transceivers
Hi all. I would like to ask for help, because I`m not really versed in this issue.
The essence of the problem in incorrect actuation at block synchronization word search, and as result, thetransmission output wrong data. The error occurs infrequently, aboutonce every 4-5 launches, the laws in these appearances is not defined.
Board EP4CGX30BF14C8, Functional mode - Basic.
language - Verilog HDL, input clock frequency - 120MHz, channel - fiber.
Script and timing diagrams with examples of correct operations and error in attachments.
Do you observe the same with Modelsim simulation?
Yes, the Modelsim simulation result is the same
If issue can be observed in Modelsim simulation, it is likely due to transceiver configuration or test bench related issue. Are you performing loopback from TX to RX in simulation and observe error at RX?
You can try to start simple by sending only fixed data pattern. This will ease the debugging.
That's what I did. The problem is that a fixed set of data does not display false positives. And with the right - all in their places.
The problem is unlikely transceiver configuration as in the test stand.
If there is no issue when sending fixed data, then probably you should further check your data generator in your design for anomaly.
When sending a fixed data, there is no problem only if the right triggers. Since in this case we see, and sent a set of triggering and synchronization of a given word. But also in this case are false tripping, the feast which the output is not seen nothing but trash
