Hello, All
Now I need your help. In my project, the FPGA is EP4CE15F17C8. The EPCS is EPCS16. The EPCS has been divided into 4 parts (each is 4Mb), which are used for different program and user data. The part 1 of EPCS is used to write factory program, and the part 2 and part 3 of EPCS is used to write two program, and the part 4 is for user data. The format of factory program is JIC, and it will be download by JTAG. The size fo JIC file is 2MB. How much space of EPCS will JIC file occupy? The format of application program is RBF, and it will be download by orhter interface. Thank you very much. Best regards.Link Copied
