I encounter timing issue when I do costraint for high speed ADC.
the ADC's sample clock rate is 40MHz,resolution is 12bit. There is 8 channels for each ADC.(the device is AD9279) the speed rate between ADC and FPGA is 480mbps,and the dclk is 240MHz. The I/O timing constaints cannot be met for the clock delay is too huge. I watch the route path by chip planner and find that the clock takes a detour. I have tried to resolve the problem by many ways,like to change parameter of the filtter, but it is useless. So how to resolve the problem.- Tags:
- Cyclone® V FPGAs
Topic Options
