21591 Discussions
Cyclone V: 5CEBA9F31C7 timing issue for high speed ADC
I encounter timing issue when I do costraint for high speed ADC.
the ADC's sample clock rate is 40MHz,resolution is 12bit.
There is 8 channels for each ADC.(the device is AD9279)
the speed rate between ADC and FPGA is 480mbps,and the dclk is 240MHz.
The I/O timing constaints cannot be met for the clock delay is too huge.
I watch the route path by chip planner and find that the clock takes a detour.
I have tried to resolve the problem by many ways,like to change parameter of the filtter,
but it is useless.
So how to resolve the problem.
