21607 Discussions
Cyclone V - DE10-Nano Kit - JTAG Chain Debugging - Incorrect IDCODE
ieeeHuseyin
I am conducting some experiments with the De10 Nano board via JTAG.
I am using Quartus' JTAG chain debugging application for this purpose.
For example, I want to read the IDCODE registers.
I have researched the necessary IR (Instruction Register) commands from the BSDL files.
In the experiments I conducted, I can correctly read the FPGA's IDCODE register, but I cannot read the HPS's IDCODE register correctly.
While the HPS's IDCODE value should be 4BA00477, the value read with the JTAG Chain Debugger appears as 974008EE (It seems like a 1-bit right shift is required).
The uploaded PDF file below also contains detailed images.
Why am I not able to read the HPS side correctly?
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
