Programmable Devices
21616 Discussions
Cyclone V, HPS SPI routing to FPGA pins
Hello everyone,
I'm using the DE0-Nano Soc Board and tried to route the signals of the HPS SPI Master Peripheral to FPGA Pins.
In Qsys i activated the SPI Master and set the pins to FPGA. In top_level entity they are connected to fpga pins.
The problem is, that the Fitter isn't able to route the sclk signal to the fpga pin i have assigned. When i don't assign a pin, the fitter can place it to some pin locations.
With assigned pins i get the following error messages.
Error (175020): The Fitter cannot place logic auto-promoted clock driver that is part of Arria V/Cyclone V Hard Processor System soc_system_hps_0 in region (28, 8) to (68, 61), to which it is constrained, because there are no valid locations in the region for logic of this type. Info (14596): Information about the failing component(s): Info (175028): The auto-promoted clock driver name(s): soc_system:qsys_system|soc_system_hps_0:hps_0|soc_system_hps_0_fpga_interfaces:fpga_interfaces|spim0_sclk_out~CLKENA0 Error (16234): No legal location could be found out of 30 considered location(s). Reasons why each location could not be used are summarized below: Error (15123): The following auto-promoted clock driver locations cannot route to all the required pins Info (175027): Destination: pin fpga_spi0_sclk Info (175015): The I/O pad fpga_spi0_sclk is constrained to the location PIN_AE12 due to: User Location Constraints (PIN_AE12) Info (14709): The constrained I/O pad is contained within this pin Info (175029): 11 locations affected Info (175029): CLKCTRL_R0 Info (175029): CLKCTRL_R2 Info (175029): CLKCTRL_R4 Info (175029): CLKCTRL_R6 Info (175029): CLKCTRL_R8 Info (175029): CLKCTRL_R70 Info (175029): CLKCTRL_R72 Info (175029): CLKCTRL_R74 Info (175029): CLKCTRL_R76 Info (175029): CLKCTRL_R78 Info (175029): CLKCTRL_R80 Info (175013): The auto-promoted clock driver is constrained to the region (28, 8) to (68, 61) due to related logic Info (175015): The HPS_INTERFACE_PERIPHERAL_SPI_MASTER soc_system:qsys_system|soc_system_hps_0:hps_0|soc_system_hps_0_fpga_interfaces:fpga_interfaces|peripheral_spim0 is constrained to the location HPSINTERFACEPERIPHERALSPIMASTER_X32_Y44_N111 due to: User Location Constraints (HPSINTERFACEPERIPHERALSPIMASTER_X32_Y44_N111) Info (14709): The constrained HPS_INTERFACE_PERIPHERAL_SPI_MASTER drives this auto-promoted clock driver Error (175006): Could not find path between source HPS_INTERFACE_PERIPHERAL_SPI_MASTER and the auto-promoted clock driver Info (175026): Source: HPS_INTERFACE_PERIPHERAL_SPI_MASTER soc_system:qsys_system|soc_system_hps_0:hps_0|soc_system_hps_0_fpga_interfaces:fpga_interfaces|peripheral_spim0 Info (175015): The HPS_INTERFACE_PERIPHERAL_SPI_MASTER soc_system:qsys_system|soc_system_hps_0:hps_0|soc_system_hps_0_fpga_interfaces:fpga_interfaces|peripheral_spim0 is constrained to the location HPSINTERFACEPERIPHERALSPIMASTER_X32_Y44_N111 due to: User Location Constraints (HPSINTERFACEPERIPHERALSPIMASTER_X32_Y44_N111) Info (175021): The HPS_INTERFACE_PERIPHERAL_SPI_MASTER was placed in location HPSINTERFACEPERIPHERALSPIMASTER_X32_Y44_N111 Error (175022): The auto-promoted clock driver could not be placed in any location to satisfy its connectivity requirements Info (175029): 19 locations affected Info (175029): CLKCTRL_G12 Info (175029): CLKCTRL_G13 Info (175029): CLKCTRL_G14 Info (175029): CLKCTRL_G15 Info (175029): CLKCTRL_R1 Info (175029): CLKCTRL_R3 Info (175029): CLKCTRL_R5 Info (175029): CLKCTRL_R7 Info (175029): CLKCTRL_R9 Info (175029): CLKCTRL_G8 Info (175029): CLKCTRL_G9 Info (175029): CLKCTRL_G10 Info (175029): and 7 more locations not displayed
I think that there are some restrictions which pins the peripherals of the hps can access in the fpga region, but i wasn't able to find something about it in the device handbook.
It's also possible that i haven't the right settings in my project, so have sombody else succesfully placed the spi signals in the fpga region and can give me some tips?
Best regards
Bjoern
I have send an Service Request to Altera and got an answer today.
It seems to be a bug in the quartus software, and the workaround is described here: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd10132014_244.html
Maybe this solution helps someone else in the future.
Hello Captain-Chaos,
I'm facing the same problem while exporting the spi_clk hps signal to fpga and got this error. Did you managed to solve it? I used the workaround posted but the error is still there.
--- Quote Start ---
--- Quote End ---
Hey,
in my Design the solution with an boolean combinational function works fine. Did you try this or the maual LUT instantiation?
AN706 (https://www.altera.com/documentation/mwh1410561892049.html) describes the reqired steps to export the perihperals, have you checked that there is no fault in your design?
Just had the same issue (w/ Q16.1) and that did the trick. Thanks for the heads-up on this.
