21588 Discussions
Cyclone V: How to generate a Trigger Signal ?
Can anyone suggest me, how to create trigger signal for controlling 128 bits counter data ?
What you want to control with counter?
Enable can also be used as trigger.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
--- Quote Start ---
Anand Raj Shankar
--- Quote End ---
Actually what i am trying to do :( Sending LVDS signal [128 bits counter data] from cyclone V to XILINX Custom Board, and trying to control LVDS signal through trigger in NIOS Processor. I worked in XILINX but i am new to Altera and Qsys. So please help me in this part. I need to try the LVDS signal through trigger via NIOS Processor. How ? ?
You can use on chip memory as register.
use one of the memory address like register and assign a bit to trigger the counter in a c-code in eclipse design. This bit to be used in you HDL coding to trigger counter.
(embedded code<->Nios<->On-chip memory<->user logic)
Look into below link you may get some idea.
http://scale.engin.brown.edu/classes/en2911xf14/qsys_comp.pdf
Let me know if you need any further assistance.
Anand Raj Shankar
SS5
I am trying to generate Trigger signals and Counter data through Quartus and NIOS.
Verilog code:
module Counter( input clk, input enable, input reset, output reg[31:0] Final_value // output wire trig ); reg[31:0] counter_out; reg [7:0] temp=0; reg [31:0] counter_result; wire temp1; wire temp2; reg trig; always@(posedge clk or negedge reset) begin if(~reset) begin trig<=0; temp<=0; counter_out<=0; end else if (enable==1'b1) begin counter_out<=counter_out+1; temp<=temp+1; if(temp==25) begin temp<=0; trig<=~trig; end   end   assign temp1=trig; assign temp2=temp1&&clk; always@(posedge temp2 or negedge reset) if(~reset) counter_result<=0; else begin counter_result<=counter_result+1; end always@(posedge trig or negedge reset) if(~reset) Final_value<=0; else begin Final_value<=counter_result; end endmodule
Enable signal is coming from NIOS through PIO. After receiving the enable bit, code should generate Trigger signal, and at every neck edge (either positive or negative) i need to store the counter data in register.
For above process, i have used AVALON FIFO core, but in NIOS console i am not getting proper counter data. Please suggest me
