21569 Discussions
Cyclone V VCCPD = 1.8V
AWann1
Hello, I've been given this CCA to program, it contains a Cyclone V, 5CEFA5.
The config memory is 1.8V, so the programming bank 3A is set to 1.8V.
VCCIO3A is 1.8V, VCCPGM is 1.8V.
But, it looks like VCCPD3A is tied to 1.8V. I know it should be set to 2.5V.
I am having no luck connecting via JTAG.
Is this VCCPD3A being tied to 1.8V the reason why? And is there anyway to fix this without redoing the entire board?
Farabi
Is it possible to share the schematic on JTAG / config connection? so we can understand more on the connection.
regards,
Farabi
AWann1
Sure, here are sections of the schematic with the JTAG connections and the power connections
AWann1
Hi, I was curious if anyone had any insight to this issue.
NurAiman_M_Intel
Apologize for the delay in response.
Per your statement below;
 'it looks like VCCPD3A is tied to 1.8V. I know it should be set to 2.5V.'
Please clarify. Do you mean it is set automatically to 1.8V?
Any error message you get?
Can you explain further.
Aiman
AWann1
In the attached schematic above, you can see there was an error in the connection. The pin VCCPD3A is tied to 1.8V, when, according to the pin connection guidelines PCG-01014-3.2, the PD pins should not be less than 2.5V.
When I attempt to connect to the FPGA via JTAG, I get a JTAG error. I am wondering if this voltage pin is the reason why. And, if there is anything I can do to get around this.
NurAiman_M_Intel
Yes, the VCCPD3A is giving you the error. You need to follow the pin connection guidelines for this case. Please set is to 2.5V and above per recommended by the guidelines.
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
