21616 Discussions
Cyclone V don't work at low temperature
Hi,all
I design a digital image precessing board using the Cyclone V 5CEBA4U15I7N. It works well at normal temperature.
It don't work under -15℃ when there is no FPGA work current. But it's OK for the power voltage,power sequence and oscillator frequence under -15℃.
what's the reason?
Thank you for your reply.
Best regards.
Jimmy
This part is rated to work even at temperatures under -15oC, so it should work.
Are you sure that all the other ICs assembled on this board are really specified to work under such temperature ?
I check the other ICs. the problem come from the flash. The flash don't work at the low temperatur.
Thanks for your suggestion.
