21602 Discussions
Cyclone V remote update failed by nStatus negative pulse.
I am using cyclone V with S25FL064 flash.
I generate a sof with rsu for both factory image and user image, and coverted all of them into .flash. The address of two apps is just after the sof.
Address arrangement(memory map):
Factory:
0x000000 sof
0x17xxxx factory image
User:
0x200000 sof
0x37xxxx User image
All of the .flash are burned into S25FL064 with nios2-flash-programmer.
After resetting, the factory image boots well and starts to reconfig to user image, but it fails to reconfig to the user image and reboots again.
From the scope, I capture a negative pulse on nStatus, at the same time conf_done also goes low (keep low around 600ms, then goes high. I think it because the reboot succeeds), nothing changes on nConfig.
After reboot, the rsu status is read as 0x04 which indicates nStatus fail.
Could anyone help? I do very appreciate for any proposal.
Best Regards
hdai
