21604 Discussions
Cyclone iii developpment board: DVI HSMC problem
I use a module for cyclone iii to test my hsmc DVI I/O but I always have this strange message on my monitor: "Input Signal out of rang, chang setting to 1600*900-60hz".
What can I do to resolve this problem?
the source of image is a PC via an input DVI of HSMC DVI.
Cordially.
It seems that the Synchronization and/or Clock is not correct.
Please give more details about your Configuration including the used Modules inside the FPGA, and the resolution settings of the PC-Output, etc.
--- Quote Start ---
Please give more details about your Configuration including the used Modules inside the FPGA, and the resolution settings of the PC-Output, etc.[/QU
I used a dvi-in and dvi-out clocked video input and another for output:
http://www.alteraforum.com/forum/attachment.php?attachmentid=9894&stc=1
and for the input clock it is 108Mhz:
http://www.alteraforum.com/forum/attachment.php?attachmentid=9895&stc=1
the Sopc builder module is:
http://www.alteraforum.com/forum/attachment.php?attachmentid=9896&stc=1
thank you for replying.
I use a clocked video IP for the DVI-in and DVI-out, the parametre that I use are: 1600x900 and an output clock of 108Mhz. I try to put images to explain the situation bu I can't apload it.
Thank you
-could you try to use QSYS for the whole system?
-Could you try to get all the memory stuff out first and connect a Test-Pattern-Generator directly to the Clocked-Video-Output?
