Programmable Devices
21592 토론
D5M not working with DE1-SoC
명예로운 기여자 II
2,474 조회수
Hi all, hopefully this is the right place to post this.
I am working on a project using the DE1-SoC that will be implementing image processing. I am using the D5M camera and Quartus II software. I downloaded the DE1_D5M project (http://www.codeforge.com/article/236879) and changed it up so that the pins match up with DE1-SoC. I don't get any errors, just two critical warnings saying that timing requirements are not met and a few other warnings. The code compiles and is able to be uploaded to the board. However, the monitor does not display anything after I have connected the VGA cable. Has anyone gotten this to work for the DE1-SoC? And if so how did you modify the original file?
Thanks!
0 포인트
5 응답
명예로운 기여자 II
925 조회수
In rar-archive on link is present "DE1_D5M.sof". It is for your board ?
You may use it direct without changing sources ?
0 포인트
명예로운 기여자 II
925 조회수
Actually got it all up and working. If you email their tech support, they will send you a version of the code that works for the DE1-SoC. Its just not on their site
Thanks anyways though:)
0 포인트
명예로운 기여자 II
925 조회수
--- Quote Start ---
--- Quote End ---
I haven't had the same luck with tech support. Can you please send me what they sent you?
0 포인트
명예로운 기여자 II
925 조회수
--- Quote Start ---
--- Quote End ---
Same Problem here can u share your Qsys file with me ?
0 포인트
명예로운 기여자 II
925 조회수
can u share it with me?
0 포인트
응답
