DDC using Qsys
Hello!I want to make digital down converter on Cyclon V (Quartus 14).
DDC is a blackbox with cic and fir filters, nco and two muls. Input signal width - 16 bits.
First, I joined some IP cores: nco, mul, cic and fir filters and simulated it in modelSim in Quartus.
I want to control DDC and receive data from DDC via SPI. Qsys containe SPI core, so I decided to make ddc in Qsys, but CIC filter and nco doesn't supported for Cyclone V.
Is it a mistake or I do something wrong?
Please advice me the best way to do this task.
I don't think you are doing anything wrong, for some reason that IP is coded to tell Qsys it's not supported. I looked at the NCO documentation and it doesn't list Cyclone V as a supported device but on the next page resource usage targetting a Cyclone V device is listed so I'm not sure if it not being supported is a mistake. I recommend opening a service request since if this is a bug the support team might be able to should you how to work around the issue.
I've downloaded Quartus 14.1 and find all components except multiplier(
where does multiplier locate in qsys?
