21615 Discussions
DDR SDRAM connection to FPGA
I'm trying to design a board for EP3C16Q240C8N FPGA and MT46V16M16P DDR SDRAM. I have read some application notes which say that I have to connect SDRAM data lines to DQ/DQS blocks. My selected FPGA has 4 blocks of x8 DQ/DQS pins, but they are placed each on other side and bank of chip. So my question is - is it OK, to connect SDRAM data pins to two x8 DQ/DQS blocks which are placed on different sides?
Thanks!
Janis
Yes, it is OK to do so.
Beware that you only can connect the DM pins on the Top and Bottom bank.
Thanks josyb!
