21616 Discussions
DDR SDRAM pin assign problem
I'm trying to have a pin-assignment of EP3C55U484C7 with DDR SDRAM.
I read the pin information for the Cyclone III EP3C55 device. but after assignment, threre are errors during compilation as "The assigned locatino PIN AB16 for DQ pin "ddr_dq[8]" is not a legal location".
I read a lot of post and datasheet. But I didn't realize what I'm wrong. Please check the attachment which is the pin-assignment file. Please give me some advices.
Thank you for reading.
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[12]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[11]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[10]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[9]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[8]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[7]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[6]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[5]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[4]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[3]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[2]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[1]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_addr[0]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_ba[1]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_ba[0]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_cas_n
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_cke[0]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_clk[0]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_clk_n[0]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_cs_n[0]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dm[1]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dm[0]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[15]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[14]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[13]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[12]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[11]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[10]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[9]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[8]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[7]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[6]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[5]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[4]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[3]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[2]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[1]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dq[0]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dqs[1]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_dqs[0]
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_ras_n
set_instance_assignment -name IO_STANDARD "SSTL-2 CLASS I" -to ddr_we_n
set_location_assignment PIN_AB19 -to ddr_addr[12]
set_location_assignment PIN_AA19 -to ddr_addr[11]
set_location_assignment PIN_AB17 -to ddr_addr[10]
set_location_assignment PIN_AA17 -to ddr_addr[9]
set_location_assignment PIN_T14 -to ddr_addr[8]
set_location_assignment PIN_T11 -to ddr_addr[7]
set_location_assignment PIN_T10 -to ddr_addr[6]
set_location_assignment PIN_AA3 -to ddr_addr[4]
set_location_assignment PIN_Y4 -to ddr_addr[3]
set_location_assignment PIN_U8 -to ddr_addr[2]
set_location_assignment PIN_U7 -to ddr_addr[1]
set_location_assignment PIN_V6 -to ddr_addr[0]
set_location_assignment PIN_AB3 -to ddr_addr[5]
set_location_assignment PIN_V7 -to ddr_ba[1]
set_location_assignment PIN_W6 -to ddr_ba[0]
set_location_assignment PIN_AB6 -to ddr_cas_n
set_location_assignment PIN_AA6 -to ddr_cke[0]
set_location_assignment PIN_T16 -to ddr_clk[0]
set_location_assignment PIN_R16 -to ddr_clk_n[0]
set_location_assignment PIN_Y3 -to ddr_cs_n[0]
set_location_assignment PIN_AA7 -to ddr_dm[1]
set_location_assignment PIN_V5 -to ddr_dm[0]
set_location_assignment PIN_AA5 -to ddr_ras_n
set_location_assignment PIN_AB5 -to ddr_we_n
set_location_assignment PIN_AA20 -to ddr_dq[15]
set_location_assignment PIN_W17 -to ddr_dq[14]
set_location_assignment PIN_AB18 -to ddr_dq[13]
set_location_assignment PIN_T15 -to ddr_dq[12]
set_location_assignment PIN_W15 -to ddr_dq[11]
set_location_assignment PIN_V15 -to ddr_dq[10]
set_location_assignment PIN_V14 -to ddr_dq[9]
set_location_assignment PIN_AB16 -to ddr_dq[8]
set_location_assignment PIN_U12 -to ddr_dq[7]
set_location_assignment PIN_AB15 -to ddr_dq[6]
set_location_assignment PIN_AA15 -to ddr_dq[5]
set_location_assignment PIN_W13 -to ddr_dq[4]
set_location_assignment PIN_AB14 -to ddr_dq[3]
set_location_assignment PIN_AA14 -to ddr_dq[2]
set_location_assignment PIN_AB13 -to ddr_dq[1]
set_location_assignment PIN_AA13 -to ddr_dq[0]
set_location_assignment PIN_AB9 -to ddr_dqs[1]
set_location_assignment PIN_V10 -to ddr_dqs[0]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dm[1]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dm[0]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[15]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[14]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[13]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[12]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[11]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[10]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[9]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[8]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[7]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[6]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[5]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[4]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[3]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[2]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[1]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dq[0]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dqs[1]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 211315428 -to ddr_dqs[0]
Now, Compilation is finished successfully. DQs and DM were connected to DQ5B group when compilation was failed.
I got a successful compilation after I changed DQs and DM into DQ3B group.
But I can't understand the reason why. Anybody knows why?
