21602 Discussions
DDR2 SDRAM High Performance Controller - Parallel- and Serial-termination????????????
Well, I build my System via the SOPC-Builder.
Now I want to to the pinning at quartus. My Problem ist, that I got 2 signals where I dont have any idea what I should do with them.
There names:
oct_ctl_rs_value
oct_ctl_rt_value
The Manual tells me this:
ALTMEMPHY signal that specifies the serial termination value. Should
be connected to the ALT_OCT megafunction output
“Seriesterminationcontrol(oct_ctl_rs_value)
and
ALTMEMPHY signal that specifies the parallel termination value.
Should be connected to the ALT_OCT megafunction output
“Parallelterminationcontrol(oct_ctl_rt_value). What I have to do? I dont have any glue what these altera guys want from me.
Well, ok as far as I found out I have to use a Altera Megafunction called Alt Oct. Its used for termination(calibration). Its needed for Stratix III Boards. There is no intern solution so u must use this Extra-"Feature".
Well, I just working arround to get it work. ATM I just want to know how I should connect this megafunction to pins. Manual is a bit crap. At least for the pinning.
http://www.altera.com/literature/ug/alt_oct.pdf
http://www.altera.com/literature/an/an435.pdf
http://www.altera.com/literature/an/an465.pdf
Those manuals are helping too.
My only question atm is now: How to hell can I connect rup and rdn correctly to over the 50(25) ohms resistors to gnd/vcc? I got more than 1 I/O Bank. Those altera guys are a bit crazy... just use our tcl scipts... u dont need to have a glue how u make it by your owen.
