Programmable Devices
21615 Discussions
DDR3 Uniphy altera example design error in Modelsim
I'm trying to simulate the DDR3 Uniphy Memory controller example design in Modelsim, but I keep getting errors.
I did everything Altera said in its readme.txt file. Nothing helps...
In Modelsim I compile the run.do file of ALtera and after a while see:
# ** error: (vcom-1935) unable to move temporary file c: /cccc/coresddriiiuniphy/ddriiiuniphy_example_design/simulation/vhdl/mentor/libraries/work/_temp/vlog6rajn8 to c:/cccc/coresddriiiuniphy/ddriiiuniphy_example_design/simulation/vhdl/mentor/libraries/work/ddriiiuniphy_example_sim_e0_if0_s0_mm_interconnect_0_cmd_xbar_demux_001/_primary.dbs.#
# no such file or directory. (errno = enoent)
Did anyone have this error?
How to get pass it?
Thx
Can I assume you copied and pasted the error message into the post? I can't help but notice the "space" in the path of the source file. "c:_/cccc/...". Is it that the tools can't find the source file?
Cheers,
Alex
No... I just deleted my computer details. :o)
