Programmable Devices
21615 Discussions
DE1 Control Panel
Is there an option to download the DE1 control panel .exe files from the website?
--- Quote Start ---
That could have certainly been done, but that was not the way this board was designed.
--- Quote End ---
so means DE1 seven segment cathode type?
--- Quote Start ---
--- Quote End ---
Incorrect. The displays are common anode, which is connected to +3.3V. There is an inline 1K current limit resistor from the individual segment cathode to the FPGA pin.
So you need to drive a pin LOW to light the corresponding segment. So '1' = off, '0' = on are the levels required on the FPGA segment driver pins.
