21600 Discussions
DE1 SoC board USB port
Hi. May i know is it possible to give some input signal from a simulator into De1 SoC usb port?If yes, is there any configurations need to be done?If no, may i know if there is any option where can I input the signal from the simulator to the fpga?
The USB on the DE1-SoC is connected to the HPS portion, not the FPGA portion. You can boot into Linux and use applications that interface with the USB to test out your signals.
