21613 Discussions
DE1 simple question
can you write one byte from the fpga (DE1 board) to flash (on board) and if so, what is the configuration?
I don't know why you wanna use flash for that operation? You can use SRAM or SDRAM.
I would like to have fixed memory i can get (this is for using signals from keyboard to vga).
is it possible to write one from the fpga to flash on board (DE1)?
It's basically possible. However, you can only write to an erased memory location, erasure has to be done in sectors. "Write" (programming) operation as well as sector erase requires a multi-cycle sequence, consult the flash datasheet for details. DE1 has also demonstration projects, that are utilizing the flash. Unfortunately they are "illegible" uncommented Verilog code, as commonly known with Terasic Dev Kits.
thanks,
i know about this option and will check it again.
by the way how can i select a sector? i have only data and address?
