21600 Discussions
DE10 Nano flash error
i am trying to flash my program into epcs128. I followed the official tutorial in site converted the code into jic and when i try to flash i get error at 43%. Pls help me in solving this issue.
Have you flashed .sof successfully?
Try by reducing JTAG clock to 6 MHz with the command: "jtagconfig --setparam <cable name> JtagClock 6M"
Refer: https://www.altera.com/support/support-resources/support-centers/devices/cfg-index/fpga-configuration-troubleshooter.html
https://www.altera.com/en_us/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf
make sure configuration mode selected correctly.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Yes I was able to flash sof successfully. Program is also correct. Will try you solution and update now.
--- Quote Start ---
Anand Raj Shankar
--- Quote End ---
Can u tell me how to execute the above state command. I cant find any console to execute it.
Apologies for late response, caused because of email notification issues.
Use Nios II Command Shell.
Anand Raj Shankar
