21616 Discussions
DE10 lite How to simulate the design from within Quartus ?
YigalB1
I am newbie with the DE10 lite.
So far I could create the RTL, pass the synthesis (still with some warnings to investigate).
I could also simulate it with ModelSim that was installed according to DE10 Lite data book.
However, whenever I try to run the simulation from within Quartus (tools->run simulation tool-> RTL simulation) there is no error, yet nothing happens.
Gemini's AI help guided me to define ModelSim in EDA tools settings - how ever, there is no ModelSim option there.
How can I set it correctly and run it?
KennyTan_Altera
Can I assume that you are using this link? https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=234&No=1021&PartNo=4
If yes, the user guide mention that you will need to used Quartus 16.0. If you want to use the latest version, you will need to do the migration and study the flow again to run the simulation.
If the above is link is not correct, kindly send us your link.
sstrell
What version of Quartus are you using?  ModelSim (or in more recent versions QuestaSim) must be installed along with Quartus.  If you didn't install the simulation tool and set the path to its executable in the settings, it won't work.
KennyTan_Altera
Yes, do let us the version of the Quartus that you were using. As different version of Quartus use different steps for simulation.
YigalB1
I am using version 23.1 build 991 11/28/2023 SC lite Edition.
What version should I change to? (as long as it supports the DE10 Lite)
sstrell
YigalB1
I have modelSim installed, according to the DE10-Lite user manual.
Simulation is running well on ModelSim stand alone, but so far I failed to run the verilog simulation or gate level simulation out of the Quartus tools menu.
ModelSIm version is 2016.10
KennyTan_Altera
Also, can you use our latest Quartus Prine Pro/Std? As using the old version of Quartus will not help on the support side.
KennyTan_Altera
KennyTan_Altera
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions
