Programmable Devices
21611 Discussions
DEO_Nano as onboard system
Hi Guys,
I am still beginner in FPGA.
May i ask some suggestions?
Now, i am doing project with DEO_Nano ALTERA Cyclone IV.
I use QUARTUS II 10.1 and NIOS II.
I want to make my system as onboard system.
So, in the future i want to use battery as power source for my DEO_Nano board.
Then, my question is:
How to make my DEO_Nano don't need to be upload the program again at power-on and don't lose that configuration when the power goes off (battery as power source), but i still can upload new code to the board if i build new code.
So, it will be similar with others microcontroller.
Thank you so much for your help.
Start a tool called "Flash Programmer" from Eclipse, add your *.sof and *.elf files, the program EPCS device. You will be able to re-configure FPGA over JTAG with your "new code" later if needed.
--- Quote Start ---
--- Quote End ---
Thank you for your reply.
So, it's that mean i should use EPCS as my board memory?
What's "board memory"? You need an EPCS device to store configuration data for your FPGA. Here is some additional info: http://www.altera.com/literature/hb/cfg/cfg_cf51001.pdf
oh okay,
i mean, when we build SOPC builder what kind of memory should be used, usually i use on chip memory or SDRAM.
and then, what's the difference between EPCS and Flash Memory Interface?
Thank you.
You are the designer and you decide what to use, on-chip RAM, SDRAM, MRAM, etc.
What's Flash Memory Interface? I did not found this one in QSYS.
