Hello!
I have a little problem whit a design file, i have a Stratix II board model: EP2S60F672C3 and when i open my design file DESign.sof whit the Programmer in Quartus II i see the file whit other device: EP20K200EF484. Error: Can't configure device. Expected JTAG ID code 0x082000DD for device 1, but found JTAG ID code 0x120930DD. Error: Operation failed. These are the errors i get when i try to start this file... Id like to know how could i change the device for that file to make that file for my device... I will apreciate youre help and assitance. Thank you!Link Copied
--- Quote Start --- Hello! I have a little problem whit a design file, i have a Stratix II board model: EP2S60F672C3 and when i open my design file DESign.sof whit the Programmer in Quartus II i see the file whit other device: EP20K200EF484. Error: Can't configure device. Expected JTAG ID code 0x082000DD for device 1, but found JTAG ID code 0x120930DD. Error: Operation failed. These are the errors i get when i try to start this file... Id like to know how could i change the device for that file to make that file for my device... I will apreciate youre help and assitance. Thank you! --- Quote End --- Hi, how do you generate the design.sof file ?
In menu:
assignments->device choose your Stratix II device. and Compile again.- Mark as New
Hello Pletz!
Well i didnt generated this file, i have downloaded it from a website. Is there a way i can convert this file to fit on my board? I have started to read on altera website help and learning but it looks like im far away from my interests. The file is part of a des key extractor. Hello Parrado! I have tryed manny times i have started to read on altera website help and documentation regarding Quartus II software and found this, so i have tryed i selected my device but compilation was unsuccessfull all the times manny errors. I uploaded the files in discussion now so maybe i can get better help. I also look on altera video demos on compiling programming and i started learning but at the moment i am in the very beginning phase... from what i understood is that i can design almost any kind of electronics so i have more questions regarding this board... is it posible to use it as a LAN card to my computer? Video card? Thank you all for youre respnoses!- Mark as New
A FPGA configuration file can't be converted to another device type, it has to be generated from the original project files. The appended files however aren't a complete project.
--- Quote Start --- Hello Pletz! Well i didnt generated this file, i have downloaded it from a website. Is there a way i can convert this file to fit on my board? I have started to read on altera website help and learning but it looks like im far away from my interests. The file is part of a des key extractor. Hello Parrado! I have tryed manny times i have started to read on altera website help and documentation regarding Quartus II software and found this, so i have tryed i selected my device but compilation was unsuccessfull all the times manny errors. I uploaded the files in discussion now so maybe i can get better help. I also look on altera video demos on compiling programming and i started learning but at the moment i am in the very beginning phase... from what i understood is that i can design almost any kind of electronics so i have more questions regarding this board... is it posible to use it as a LAN card to my computer? Video card? Thank you all for youre respnoses! --- Quote End --- Hi, I have setup a project for you. Unfortunately the design files are not complete. The Nois is missing, but maybe you can use the project as starting point.
Pletz
Nois or Nios? You mean Nios II processor? id like to learn making one... :)- Mark as New
--- Quote Start --- Pletz Nois or Nios? You mean Nios II processor? id like to learn making one... :) --- Quote End --- Yes, I mean the the Nios II processor. It lookslike that he is used in the tutorial. Is there no description in the tutorial how to generate the Nios II ? I would expect that the required design files are somewhere in the tutorial database.
I saw Quartus have ed8b10b encoder/decoder, anyone can help me whit this? how to? i have read and follow the steps in /ug-ed8b10b.pdf literature but i have problems loading the libraries. Is there anyone to have this encoder/decoder available? Mail it? :) please.
For Altera 8B/10B encoder IP core you need to purchase a separate license to use it in your application. It's available for free OpenCore Plus Evaluation as described in the user guide. You can also find free 8B/10B cores at opencores.org.
