21579 Discussions
DK-DEV-5CSXC6N-B - Require assistance with technical aspects.
Jonel1
I am interested in the DK-DEV-5CSXC6N-B development kit. Could someone contact us to discuss technical details regarding hardware, firmware, and software? We are developing a product for aviation applications.
khtan
Hi Jonel1 ,
Sorry for the delay in getting back, have you contacted the local sales people in your region or through our vendors for the Cyclone V board?
Kian
khtan
Did you try using this form https://www.altera.com/contact to email our sales representative or distributor network or do you have any specific questions in mind?
Kian
Jonel1
Dear Intel Team / khtan,
Our team in Irving, Texas, has developed a prototype for an Ethernet implementation tailored for avionics design, utilizing the 5CSXFC6D6F31C6N FPGA and the KSZ8873MLL integrated 3-port 10/100 managed switch with PHYs IC. We are currently facing challenges with Ethernet speed performance. We’ve observed that your DK-DEV-5CSXC6N-B evaluation board employs a different PHY, the DP83849CVS/NOPB, which may be relevant to our performance issues.
As we integrate the evaluation board circuitry, we have specific questions about hardware and FPGA code integration to optimize Ethernet performance:
Hardware: Could a technical expert provide detailed insights into the operation of the evaluation board’s PHY circuit and its integration with the FPGA?
FPGA Code: We’ve reviewed sample codes, but they appear tailored for a Renesas PHY IC. Could you provide guidance or resources on adapting these for the TI DP83849CVS/NOPB PHY IC?
To address these challenges thoroughly, we request a meeting with your team to discuss these topics in detail. Any relevant documentation or resources you could share in advance would be greatly appreciated. Please let us know your availability and any preparatory materials we should review.
Thank you for your support. We look forward to your response and arranging a suitable time to connect. Please email me at <email removed for privacy>
khtan
Hi Jonel,
Thanks for the reply and the background of the request, I'm currently checking with our NA sales team whether they are able to connect to you directly to discuss further.
Kian
Jonel1
Hello Kian,
I understand that your primary focus is on providing sales support; however, we are in urgent need of technical assistance at the moment, and I hope you understand. I would like to ask a few questions regarding the FPGA code we’re working on. Currently, we are using U-Boot as the boot loader, along with .jic and .rbf for programming. My specific questions are
  1. Our FPGA code for Ethernet is connected to the HPS with an HPS wrapper, whereas in the Intel Eval Kit, the Tri-Speed MAC soft core is used. Is there any advantage to using the Tri-Speed MAC in this case?
  2.
  3. Regarding the low-speed results we are seeing, what possible code improvements would you recommend? If feasible, we would also appreciate the opportunity to discuss this further with you.
Jonel1
Hello Kian,
I’d like to kindly follow up since it has been a few days without a response. We have identified a possible cause of the issue—using ethtool, we observed that the link is running at 10 Mbps half-duplex, even though we intended it to be 100 Mbps full-duplex.
May I ask if Intel could provide guidance on this, particularly regarding the software side and any recommended FPGA driver configurations that might help resolve the issue?
