21615 Discussions
DMA transfer from FIFO to DDR2
I am using Altera DMA controller to tranfer data from the FIFO to the DDR2 controller.But i want to start the DMA request while the FIFO is empty also i need to make the DMA wait while the FIFO is empty .So the transfer is done when the FIFO is empty.
the following is the NIOSII code i use for dma transfer :
--- Quote Start ---
void use_dma_st_mem(void* src,void* dest,alt_u32 length)
int rc;
alt_dma_txchan txchan;
alt_dma_rxchan rxchan;
printf("start use_dma_st_mem\n");
/* Create the transmit channel */
if ((txchan = alt_dma_txchan_open("/dev/dma_0")) == NULL)
printf ("Failed to open transmit channel\n");
exit (1);
/* Create the receive channel */
if ((rxchan = alt_dma_rxchan_open("/dev/dma_0")) == NULL)
printf ("Failed to open receive channel\n");
exit (1);
/// Streaming from Trasnmit channel
if ((rc = alt_dma_txchan_ioctl (txchan,ALT_DMA_TX_STREAM_ON ,src)) < 0)
printf ("Failed to post alt_dma_txchan_ioctl = %i\n", rc);
exit (1);
/// configuring receiver channel
if ((rc = alt_dma_rxchan_ioctl (rxchan,ALT_DMA_RX_ONLY_ON
,dest)) < 0)
exit (1);
/* Post the transmit request */
if ((rc = alt_dma_txchan_send (txchan,
src,
length,
NULL,
NULL)) < 0)
printf ("Failed to post transmit request, reason = %i\n", rc);
exit (1);
/* Post the receive request */
if ((rc = alt_dma_rxchan_prepare (rxchan,
dest,
length,
done_rx,
NULL)) < 0)
printf ("Failed to post read request, reason = %i\n", rc);
exit (1);
/* wait for transfer to complete */
printf ("waiting tx_done!\n");
while (!done_rx);
printf ("Transfer successful!\n");
return 0;
--- Quote End ---
