21594 Discussions
DS-5 Debug error: Unable to connect to the device
I have been following the workshop material from Arrow for SoC kits. (Here's the link: http://www.rocketboards.org/foswiki/documentation/arrowsockitevaluationboard#workshop_labs
Everything is perfect until I get to DS-5.
I've attached a screenshot of the error I get when I try to debug. Under Debug configuration -> Connection, I do select Debug Cortex A9_0 via USB Blaster as the target and then select 'CV SoCKit on localhost [USB-1]:CV SoCKit USB-1' as Connection.
The fact that I see the option to choose Cyclone V as the target must mean I have the correct license file, right?
It says it is not able to connect to the device despite setting the connections. I do not understand why. Additional to this is the FLEXnet licensing error. Is there something I am overlooking here?
Has anyone faced this issue and gotten around it? Help please!
Thank you,
Surabhi
