21611 Discussions
Debouncer verilog code
Hi you
I wrote a simple code for a debouncer circuit, and I appreciate if you can have a look and correct what's wrong.
module debouncer (noisy,clk_1KHz,debounced); input wire clk_1KHz, noisy; output wire debounced; reg cnt; //counter: waits that button is pressed at least 10ms always @ (posedge clk_1KHz) begin if (noisy) cnt <= cnt + 1'b1; else cnt <= 0; end assign debounced = (cnt==4'b1010) ? 1'b1 : 1'b0; endmodule what you think about it?:confused:
thank you all
GP
module debouncer (noisy,clk_1KHz,debounced); input wire clk_1KHz, noisy; output reg debounced; reg reg; //reg: wait for stable always @ (posedge clk_1KHz) begin reg <= {reg,noisy}; //shift register if(reg == 8'b00000000) debounced <= 1'b0; else if(reg == 8'b11111111) debounced <= 1'b1; else debounced <= debounced; end endmodule
Thank you for your fast reply!:)
dear ARTEM_BOND,
I read your post, and I found their brilliant solution!
I'm trying to build a simple and efficient verilog code, to solve the problem of noise...
I made the following modification in your code, hoping to get a greater number of shifts:
module debouncer (noisy, clock, debounced); input wire clock, noisy; output reg debounced; parameter M = 8; reg reg; //reg: wait for stable always @ (posedge clock) begin reg <= {reg,noisy}; // N shift register if(reg == (2**M)*0) debounced <= 1'b0; else if(reg == (2**M)-1) debounced <= 1'b1; else debounced <= debounced; end endmodule
I think something is wrong in the code because I can notice any noise,
by oscilloscope, even increased the value of M.
Could you help me with this?
Couple of suggestions:
(1) Instead of doing:
(reg == (2**M)*0)
you could do:
(~|reg)
And similarly for:
(reg == (2**M)-1)
do:
(&reg)
Personally I think it looks cleaner.
(2) It is really not a good idea to call a register 'reg'. 'reg' is a reserved keyword and should be used as the name. Perhaps a better name would be:
reg shift;
Or something similar.
dear TCWORLD,
I would like to clarify that this code is written by the
Altera Teacher ARTEM_BOND and "reg" is authored by himself.
I left exactly as he wrote, to not cause confusion.
Below is my code which coincidentally, was exactly the name I used:
module debounce( input wire clock, input wire IN, output reg OUT ); parameter M = 8; reg shift; //shift: wait for stable always @ (posedge clock) begin shift <= {shift,IN}; // N shift register // if(shift == (2**M)*0) if(~|shift) OUT <= 1'b0; // else if(shift == (2**M)-1) else if(&shift) OUT <= 1'b1; else OUT <= OUT; end endmodule
If I understand correctly what you suggested, their changes are only to make the code cleaner...
It really was it, nothing worked to help me, because nothing was fixed!!!
As I requested earlier:
..."I think something is wrong in the code because I can notice any noise,
Could you help me with this?"
(Excuse me if not expressed myself correctly, my English is not very good.)
sintech
For someone who found this topic looking for a working debouncer.
The correct code:
module debounce(
    input wire clock,
    input wire IN,
    output reg OUT
 parameter M = 8;
 reg [M:0]shift;
 begin
   if(~|shift)
     OUT <= 1'b0;
   else if(&shift)
     OUT <= 1'b1;
   else OUT <= OUT;
 end
 endmodule
