Programmable Devices
Comunicados
21615 Discussões
Debugging key pressed on DE2 board
Colaborador honorário II
1.466 Visualizações
See second post for the solution
I am trying to hook up the VGA and Keyboard together. So when user presses 'W', it means move the object on the screen up. Letter 'S' is downward.
I am having problem getting my code working properly. So I am debugging W and S now (up, and down, respectively).
block diagram
keyboard scan code layout
See attachments
As you can see, I linked the outputs Up and Down (W and S, respectively) to the LED switches Red[0] and Red[1].
I have three scenarios in total (codes are provided at the end)
scenario i
Send make code
if W is detected, Red[0] is on
if S is detected, Red[1] is on
if "F0" is detected, go to Received_Break state
In the received_break state, we will receive the 2nd byte of the break code, and hence, turn off the respective Red[x] LED.
scenario ii
Send make code
if W is detected, Red [0] is on
In the receive break state, turn off Red[0]
scenario iii
Do the same as II for the letter key "S"
result:
scenario i failed. Only "S" is able to turn on the LED light. Pressing W has no effect.
Scenario II passed.
Scenario III passed.
This shows me that only one key was able to exist in my state machine. More than one is not possible. So something is not correct about my scenario I state machine.
Key Detector for W and S
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity move_key_detector is PORT( clk : IN STD_LOGIC; done : IN STD_LOGIC; hex : IN STD_LOGIC_VECTOR(7 DOWNTO 0); up, down : out std_logic ); END move_key_detector; architecture arch of move_key_detector is type statetype is (IDLE, RECEIVED_BREAK); signal current_state, next_state : statetype; signal intUp : std_logic := '0'; signal intDown : std_logic := '0'; begin up <= intUp; down <= intDown; process (Clk) begin if(rising_edge(Clk)) then current_state <= next_state; end if; end process; -- Use this for all three cases.. just comment out one of them for II and III process(done) begin if (done = '1') then if (current_state = IDLE) then if (hex = "00011100") then intUp <= '1'; --elsif(hex = "00011011") then intDown <= '1'; --check to see if a break code is sent elsif (hex = "11110000") then next_state <= RECEIVED_BREAK; end if; elsif (current_state = RECEIVED_BREAK) then if (hex = "00011100") then intUp <= '0'; --elsif(hex="00011011") then intDown <= '0'; end if; --we always go back to idle after a key is released next_state <= IDLE; end if; end if;Position Controller (calculating new position of the object after Up / Down)
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity Pos_Controler is port ( Up, Down, Reset: in std_logic; Init_X, Init_Y: out std_logic_vector(9 downto 0) ); end Pos_Controler; architecture arch of Pos_Controler is signal x, y: unsigned(9 downto 0):= "0011001000"; -- 200 begin Init_X <= std_logic_vector(x); Init_Y <= std_logic_vector(Y); Process(Reset, Up, Down) begin if(Reset = '1') then -- relocate object at (96,96) x <= "0001100000"; y <= "0001100000"; elsif(Up = '1') then y <= y+4; elsif(Down = '1') then y <= y-4; end if; end process; end arch;What's the problem here?
Thank you very much :))
edit (more testings on various of keys)
What is interesting is when we have WW, TT, SS (all the way till the bottom)
Scan code: W = 00011101, S = 00011011, T = 00101100
--Original Order --if(key) intUp <= '1', elsif(key) intDown <='1' -- Reverse is the opposite W = Up, S = Down, DOWN LED is on S = Up, W = Down, DOWN LED is on -- Reverse the order of if-statement W = Down, S = Up, DOWN LED is on S = Down, W = Up, DOWN LED is on -- Use T and S combination (original order) T = Up, S = Down, DOWN LED is on S = Up, T = Down, DOWN LED is on -- Use W and T combination W = Up, T = Down, DOWN LED is on T = Up, W = Down, DOWN LED is on -- Let's reverse the order W = Down, T = Up, DOWN LED is on T = Down, W = Up, DOWN LED is on -- Lastly, how about WW, TT, SS in original order W = Up, W = Down, UP LED is on S = Up, S = Down, UP LED is on T = Up, T = Down, UP LED is on -- In reverse order W = Down, W = Up, DOWN LED is on S = Down, S = Up, DOWN LED is on T = Down, T = Up, DOWN LED is on
1 Responder
493 Visualizações
Hi guys.
I already solved my problem. We figured that even a single press (say a second duration) could mean many many make codes are being sent out from the keyboard.
Our solution is to detect the key press at the end of the break stage (using the second byte of the break code: break code is F0 follows by the make code of the key being released).
This is our solution:
process(done) begin if(done = '1') then if(current_state = IDLE) then intLeft <= '0'; intRight <= '0'; intDown <= '0'; intUp <= '0'; int_move_en <= '0'; if (hex = "11110000") then next_state <= RECEIVED_BREAK; end if; -- if F0 is received elsif(current_state = RECEIVED_BREAK) then if(hex = "00011101") then intUp <= '1'; int_move_en <= '1'; end if; if(hex = "00011011") then intDown <= '1'; int_move_en <= '1'; end if; if(hex = "00100011") then intRight <= '1'; int_move_en <= '1'; end if; if(hex = "00011100") then intLeft <= '1'; int_move_en <= '1'; end if; next_state <= IDLE; end if; end if; end process;
Responder
