21605 Discussions
Dedicated Clock (CLK) pins
CLa_R
In my Altera Cyclone IV EP4CE10 Pin Information document, I see pins CLK1...7.
Can I use this pins as normal IO (mono or bidirezional) pins?
AnandRaj_S_Intel
Yes _CLKOUTp or _CLKOUTn pins can be used as IO(mono or bidirectional) or clock.
https://www.thailand.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-iv/pcg-01008.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
CLa_R
Thanks for your ansewer.
If I read well, in the document you showed me, the pins labeled DIFFCLK [1..7], as in my case, can be used ONLY as input pins
AnandRaj_S_Intel
Yes, ​DIFFCLK  or CLK are dedicated clock pin can be used only as Input pin.
We can also cross check using quartus tool too, we expect fitter error for such a scenario.
Anand Raj Shankar
