21611 Discussions
“Dedicated reference clock pin” and “RX reference clock pin”
Fresh_Leon
Dear,
In Arria 10 datasheet.
I found two reference clock input pin. One is "Dedicated reference clock pin" and the other is "RX reference clock pin".
I am wondering, which one is in transceiver bank, and which one is in normal bank ?
Leon
EngWei_O_Intel
Hi Yang Ni
Thanks for your inquiry. Sorry for late response as I was getting clarification on your request.
Both the pins are in transceiver bank as described below:
1. Dedicated reference clock – this is the dedicated refclk pin for XCVR. In the pin connection guideline, its name is REFLKC_GXB
2. RX reference clock pin – this is transceiver RX channel where it can be used as refclk pin as well. You can find the pin with names i.e GXB_RX, GXB_REFCLK_CH in the pin connection guideline.
Reference to pin connection guideline:
https://www.intel.com/content/www/us/en/programmable/documentation/wtw1404286459773.html
Eng Wei
EngWei_O_Intel
Hi Yang Ni
Eng Wei
EngWei_O_Intel
Hi Leon
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
You can help to set closure to this case if there is no further request needed.
Thank you.
Eng Wei
