21611 Discussions
Demultiplexer with latched value
I am using a demultiplexer with six output registers. The code is pretty simple.
process(X,sel) begin case sel is when "000"=> A <=X; when "001" => B <=X; when "010" => C <=X; when "011" => D <= X; when "100" => E <= X; when "101" => F <= X; when others =>null; end case; end process;
I do not reset output regisers since I want to preserve them. That is why I get the following warnings.
--- Quote Start ---
Warning (10631): VHDL Process Statement warning at demux.vhd(21): inferring latch(es) for signal or variable "C", which holds its previous value in one or more paths through the process
--- Quote End ---
--- Quote Start ---
Warning: Found 9 node(s) in clock paths which may be acting as ripple and/or gated clocks -- node(s) analyzed as buffer(s) resulting in clock skew
--- Quote End ---
Why is wrong to have latched output registers?
What do I need to do to remove them?
Have a read of http://www.altera.com/literature/hb/qts/qts_qii51007.pdf page 42 it explains why latches are a bad idea. In short FPGAs are built out of storage elements that are all connected to a common clock.
Thanks Uk Fixer. I found a solution added a clock to sensitivity list.
In fact, demultiplexers aren't often used. Instead, a decoder providing clock-enable signals is preferred.
Nevertheless, your VHDL code must assign every signal in order to avoid parasite latches.
process(X,sel) begin case sel is when "000"=> A<=X; B<=(others=>'0'); C<=(others=>'0'); D<=(others=>'0'); E<=(others=>'0'); F<=(others=>'0'); when "001" => A<=(others=>'0'); B<=X; C<=(others=>'0'); D<=(others=>'0'); E<=(others=>'0'); F<=(others=>'0'); when "010" => A<=(others=>'0'); B<=(others=>'0'); C<=X; D<=(others=>'0'); E<=(others=>'0'); F<=(others=>'0'); when "011" => A<=(others=>'0'); B<=(others=>'0'); C<=(others=>'0'); D<=X; E<=(others=>'0'); F<=(others=>'0'); when "100" => A<=(others=>'0'); B<=(others=>'0'); C<=(others=>'0'); D<=(others=>'0'); E<=X; F<=(others=>'0'); when "101" => A<=(others=>'0'); B<=(others=>'0'); C<=(others=>'0'); D<=(others=>'0'); E<=(others=>'0'); F<=X; end case; end process;
parrado wrote:
--- Quote Start ---
--- Quote End ---
It does not have to. As I wrote , I needed to retain the values on each itteration of next register being sent to output.
that is why , i could not issue statements such as
B<=(others=>'0');
It would reset tha value of corresponding output pins to zero, which I don't want.
Yeah, you have used the first approach.
--- Quote Start ---
--- Quote End ---
