21615 Discussions
Design not Fitting in LogicLock Regions
Hi. I am having a trouble with LogicLock Regions.
I compile the Design first with the LogicLock Regions, set to Auto and Floating.
Then once it fits correctly. I change it to Fixed.. and start again..
This Time Quartus says that the Region is too small to fit the design into it.
How can this be true? if it was Quartus the one who determine the size of it on the previous Run?
has any one had this kind of problem?
Thankyou!
is your region's location the same as when Quartus placed it? a column of DSP blocks will leave you with fewer LEs, for example
if everything checks out i would open a service request and file a bug report. in the mean time can you increase the size of the region slightly to get it to fit?
