21611 Discussions
Details about how to instantiate sdram controller module
Hi guys.
first I will mention that I tried to read and understand :"external memory interface handbook volume 2", and the questions are things that im still not understanding and need your help.
Im using MAX10 FPGA , and quartus 2.
Im trying to instantiate sdram controller to my project so Im first learning how to do it, by opening a new project.
So, those are the steps I did, and the questions I have about them:
1.ip extraction:from "ip catalog" I extracted "DDR2 SDRAM controller with uniphy".
2.atttaching files:From the files that were extracted I took the the project the qip file, which attached all the files.
q:Do I need all of those files? files like:"sdram_interface_s0.v", "sdram_interface_c0.v","alt_mem_ddrx_input_if.v" .
And Ill be happy to know what are all of those files? are they the "Inside" of the controller ?? and all I have to deal with is :"Sdram_interface.v" file??
3.pin assignments: I used the tcl script that I got from the extracted ip files.
q: Do I need anymore assignments to do?
4.instantiating the module: I instantiate this way:
sdram_interface(
.pll_ref_clk(clk), // in pll_ref_clk.clk
.global_reset_n(), // in global_reset.reset_n
.soft_reset_n(), // in soft_reset.reset_n
.afi_clk(clk), // afi_clk.clk
.afi_half_clk(), // afi_half_clk.clk
.afi_reset_n(), // afi_reset.reset_n
.afi_reset_export_n(), // afi_reset_export.reset_n
.mem_a(mema), // out memory.mem_a
.mem_ba(memba), // out .mem_ba
.mem_ck(mem_clk), // .mem_ck
.mem_ck_n(), // .mem_ck_n
.mem_cke(mem_cke), // out .mem_cke
.mem_cs_n(), // .mem_cs_n
.mem_dm(), // .mem_dm
.mem_ras_n(), // .mem_ras_n
.mem_cas_n(), // .mem_cas_n
.mem_we_n(), // .mem_we_n
.mem_dq(), // .mem_dq
.mem_dqs(), // .mem_dqs
.mem_dqs_n(), // .mem_dqs_n
.mem_odt(), // .mem_odt
.avl_ready(avl_ready), // avl.waitrequest_n
.avl_burstbegin(avl_burstbegin), // in .beginbursttransfer
.avl_addr(avl_addr), // in .address
.avl_rdata_valid(avl_rdata_valid), // out .readdatavalid
.avl_rdata(avl_rdata), // out .readdata
.avl_wdata(), // in .writedata
.avl_be(), // in .byteenable
.avl_read_req(avl_burstbegin), // in .read
.avl_write_req(1'b0), // in .write
.avl_size(2'b10), // in .burstcount
.local_init_done(), // status.local_init_done
.local_cal_success(), // .local_cal_success
.local_cal_fail() // .local_cal_fail
Im still trying to learn what each port do, so I did only the one I know and they are important.
5.wrote to the memory: I wrote to the memory using de-control panel ,and I want to check, and see if I can do a read transaction.
Q: I dont really know how to do that.. I thought about doing a test bench for the file that instantiating the sdram controller module,but it doesnt make any since.
what am i missing??!!?
Im feeling like I missing a big piece here, and Ill be happy for your help.
Thanks a lot!!!
--- Quote Start ---
--- Quote End ---
Refer “Implementing and Parameterizing Memory IP” from external memory interface handbook volume 2 & using following links generate (.v or .vhd) files.
https://www.youtube.com/watch?v=yeh2bk9pup8
http://www.altera.com/education/training/courses/omem1110
--- Quote Start ---
--- Quote End ---
Yes, these are sequencer file, controller core file, memory interface file generated during “Generate Example Design”, you should deal with “Sdram_interface.v” file & instantiate this module in your project with instance name & keep all related files at one location & add them to your project when required.
--- Quote Start ---
--- Quote End ---
It depends upon your Top module in project.
--- Quote Start ---
5.wrote to the memory:[/B][/U] I wrote to the memory using de-control panel ,and I want to check, and see if I can do a read transaction.
--- Quote End ---
To check read,write and for debug you can use signal tap.
Best Regards
Vikas Jathar
Intel Customer Support – Engineering
(Under Contract to Intel)
