21594 Discussions
Diff btw Avalon STreaming and Avalon Memory mapped
what is the Difference between Avalon ST and Memory interface. and when to select the above two interfaces?.
The Avalon memory mapped interface allows a master to access a component using random addressing. It uses both address and data vectors and can read/write any address on the slave.
The Avalon stream interface is a sequential set of data vectors sent one after the other. It is very efficient when you have a continuous flow of data to send from one source to a destination, but doesn't allow random access.
