21611 Discussions
Need help designing zero-wait-state memory.
Hi, I have an "economy" Nios2 core interfacing relatively slow external RAM chip.
I want to help with interrupt processing performance little bit by placing exception handling code in zero-wait-state on chip memory.
So far I am experiencing problems interfacing to the onchip ram. It seems I cannot achieve zero-wait-state mode.
Processor is capturing data on the bus from the previous cycle. Looks like I have to add a wait state.
Rith now I am feeding the ram block with the same system clock the cpu runs at.
Should I play with generating a second clock, which is out of phase to the system clock to make it work with zero wait states?
Do you know if there is an example design I can look at to learn how to do it right, with no need for any wait states?
Pszemol
The on-chip memory components always have at least one read wait state.
You could design your own component in HDL to create a 0 wait state memory, but it will probably have a negative impact on the system's fmax.
Thanks for the reply... I guess I will deal with 1 wait state... for now.
It is still much better than a 16bit external ram which is 55ns type.
Because it is only 16bit, it takes 2x 55ns to fetch opcode from there.
1 ws on 32bits sounds much better already.
BTW - anybody knows how big the memory cpu supposed to get for this exception vector location? And what is the reason the default values have 0x20 offest? Where can I read about what code is put there in the reset/exception vectors and how big this code is?
Pszemol
