Programmable Devices
21599 Discussions
Digi-Key only distributor?
EPM7064STC44-10 out of stock at Digi-Key. Any other stocking dealers?
I need ten pieces.
JohnP
Digi has the -7N avaliable, which should be fine although more expensive and lead free. Arrow reps altera as well(arrownac.com) although they don't have stock of the -10 either.
http://www.altera.com/corporate/contact/sales/na_distis/con-na_distis.html
Yikes, $25.
Digi-Key lead time says first week of April for the -10.
Did I design in the wrong part?
I assume, you wanted a 5V CPLD. There aren't much alternatives now. As the price clarifies, MAX7000S is clearly legacy. I think, the last time, I used it 9 years ago in a design. It's better to use recent devices, even if level converters are needed sometimes. 5 V tolerant MAX3000 is the right choice for designs that still involve 5V, for the time being. I guess, you know the current prices yourself.
This was my first design.
I used schematic entry. All pins are used, and 93% logic utilization.
Can I make a Max 3000 work in its place without designing a new pcb?
I found a reseller that has new old stock.
Gives me time to hit the books.
hi
you can contact Wt.Microelectronics or you can send me the mail, i will try to provide you
Wt.Microelectronics is the authorized distributor for the altera
