21584 Discussions
Discrepancies between datasheets and technical documentation regarding FPGA configuration.
FFmine
About Arria V data sheet
https://www.intel.com/content/www/us/en/docs/programmable/683022/current/active-serial-as-configuration-timing.html
Note 105 is as follows.
105 To evaluate the data setup (tSU) and data hold time (tDH) slack on your board in order to ensure you are meeting the tSU and tDH requirement, Intel recommends following the guideline in the "Evaluating Data Setup and Hold Timing Slack" chapter in AN822: Intel FPGA Configuration Device Migration Guideline.
However, AN822 mentioned tDSU, but tSU was no there.
https://www.intel.com/content/www/us/en/docs/programmable/683340/current/evaluating-data-setup-and-hold-timing-slack.html
Is tDSU in AN822 just a misspelling?
FvM
IMHO no misspelling, just a different valid symbol for the same measurement.
tDSU = data setup time
tSU = setup time
FFmine
Thanks for your reply
I think so too.
Your opinion has gave me confidence in my thinking.
But tDSU and tSU has different value in Arria V data sheet.
tSU value is 1.5nsec at AS configureation section and tDSU value is 5.5nsec at PS configureation section.
And, these paramaters has diffarent memo as follows.
tSU : Data setup time before the falling edge on DCLK
tDSU: DATA[] setup time before rising edge on DCLK
I realized the probrem is an explanation method for tSU is tDSU in AS configurasion section.
Thank you for your help.
TingJiangT_Intel
Glad to know your problem has been addressed. Any updates please let us know.
TingJiangT_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
