21592 Discussions
Displayport : channel reconfiguration
Hi everyone,
i struggle to make the display port work on a10 sockit.
To be more precise, i use the demo given in rocketboards, so in TX mode at 5.4Gbps, 1920x1080p test pattern gen II and Clocked Video output with colour bars to be displayed.
After AUX channel transactions, i can read that TX channel has been correctly trained (i refer to the screen resolution that has been detected)
--- Quote Start ---
------ TX Main stream attributes -----
--- Stream 0 ---
MSA lock : 1
VB-ID : 10 MISC0 : 20 MISC1 : 00
Mvid : 232F Nvid : 8000
Htotal : 2200 Vtotal : 1125
HSP : 0000 HSW : 0044
Hstart : 0192 Vstart : 0041
VSP : 0000 VSW : 0005
Hwidth : 1920 Vheight : 1080
CRC R : 22f0 CRC G : 0a2e CRC B : b7bb
--- Stream 1 ---
MSA lock : 0
VB-ID : 00 MISC0 : 00 MISC1 : 00
Mvid : 0000 Nvid : 0000
Htotal : 0000 Vtotal : 0000
HSP : 0000 HSW : 0000
Hstart : 0000 Vstart : 0000
VSP : 0000 VSW : 0000
Hwidth : 0000 Vheight : 0000
CRC R : 0000 CRC G : 0000 CRC B : 0000
-------- TX Link configuration -------
Lane count : 1
Link rate : 1620 Mbps
--- Quote End ---
But nothing happens on screen.
And i don't understand why i get only one lane count. 1.6Gbps is not enough to handle 1080p
If you have an idea, please share it. Thanks
it's ok, i missed to connect the video pll locked signal to the transceiver ....
sorry for this useless question
