Programmable Devices
공지
21615 토론
Do Arria A10 LVDS inputs support weak pull ups/downs?
명예로운 기여자 II
2,185 조회수
Does the Arria A10 support internal weak pull-ups/pull-downs on the LVDS input lines? I can't find this info in the datasheet?
0 포인트
1 응답
명예로운 기여자 II
1,329 조회수
Check for “Internal Weak Pull-Up and Weak Pull-Down Resistor” in following datasheet & Quartus tool has internal weak pull-up & LVDS options but it allows either weak Pull-up or LVDS not both simultaneously,check below snap.
https://www.altera.com/en_us/pdfs/literature/hb/arria-10/a10_datasheet.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
Intel Customer Support – Engineering
(Under Contract to Intel)
0 포인트
응답
