21570 Diskussionen
Do virtual eFuses need to be cancelled?
grspbr
Neuer Beitragender II
512Aufrufe
I have programmed an Agilex 7 FPGA with a virtual (volatile) eFuse certificate, which worked and I was able to load an encrypted bitstream, but since then I have not been able to reload the virtual eFuse certificate.
Beschriftungen (1)
1 Lösung
grspbr
366Aufrufe
The answer is no. My issue was missing a step in trying to reload the eFuse certificate - bad procedure recording on my part.
Lösung in ursprünglichem Beitrag anzeigen
2 Antworten
Farabi
Mitarbeiter
392Aufrufe
"We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
Thank you for your understanding."
grspbr
367Aufrufe
Antworten
