21615 Discussions
Does separate Configuration Flash requires for ALTERA EP4CE15F17I7N?
Tejas1
FvM
External non-volatile configuration memory is required for all FPGA that don't have internal flash like MAX10. If your system includes a microprocessor, you may alternatively use it to load the configuration bitstream from a mass storage device.
Mengzhe
Unlike CPLD like MAX 10 which has Configuration Flash Memory (CFM), external configuration memory is required for all FPGA, including Cyclone IV devices.
Under passive configuration mode, you may use other host (like a CPLD or FPGA) to transfer configuration bitstream from other memory device.
