21615 Discussions
Does the Intel Programmable Acceleration Card only support intel scalable xeon processer?
jerrylee
i have a "Intel® Programmable Acceleration Card with Intel Arria® 10 GX FPGA", i want to develope some OpenCL apps with it.
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/acceleration-card-arria-10-gx/overview.html
My computer is HP Z600 with two Intel® Xeon(R) CPU X5570 @ 2.93GHz processor , 48GB DDR3 1333 MHz ECC memory, the PCIE may be 2.0
i tried the following Stack Versions, but none of them  worked well, which made me wonder if this card does not support ordinary xeon processors, but only support the scalable xeon processors?? however, Intel officials did not clearly point out that??
1. firstly, i tried the Intel® Acceleration Stack Version 1.2.1 with ubuntu 18.04LTS
(ref:https://www.intel.cn/content/www/cn/zh/programmable/documentation/iyu1522005567196.html)
i could get some infomation, but when i excuted the cmd
$ sudo fpgainfo fme
it returned:
Board Management Controller, microcontroller FW version unavailable
Last Power Down Cause: unavailable
Last Reset Cause: unavailable (can't open)
//****** FME ******//
Object Id : 0xF200000
PCIe s:b:d:f : 0000:0F:00:0
Device Id : 0x09C4
Socket Id : 0x00
Ports Num : 01
Bitstream Id : 0x123456789ABCDEF
Bitstream Version : 1.2.3
Pr Interface Id : ce489693-98f0-5f33-946d-560708be108a
Boot Page : user
it shows "microcontroller FW version unavailable", but i found the "Pr Interface Id : ce489693-98f0-5f33-946d-560708be108a", it indicates a previous stack Version 1.0 or 1.1 is needed(ref: https://www.intel.com/content/www/jp/ja/programmable/documentation/dnv1485190478614.html#uul1498519508520)
2. so ,i tried the Intel® Acceleration Stack Version 1.0 and 1.1 with CentOS 7.4
(https://www.intel.com/content/www/jp/ja/programmable/documentation/dnv1485190478614.html#uul1498519508520)
all installation steps were finished by tht guide! but when i want to Identify the FPGA Interface Manager (FIM) Version Loaded, it run the
$ sudo fpgainfo fme
but it returned:
WARNING: No sysfs paths found
Stack Version 1.0 and 1.1 have the same response!!
Indeed, i tried it on HP Z840, with more mordern CPU, memory and PCIE, but the
 cmd
$ sudo fpgainfo fme
did not work, too! so ,what should i do to solve those hard problems??
Do i have to purchase a intel scalable xeon processor?? i just need the OpenCL, the others is not important.
thanks, I earnestly hope to get your attention and reply
ChenSheng
Hello.
Have you solved it? I encounter the same problem.
ChenSheng
The message "Board Management Controller, microcontroller FW version unavailable" probably means the BMC firmware version is not compatible with FIM version, because this two have strict correspondence . In my opinion,  you can use bitware tools to check the BMC version through the USB wire and update the BMC firmware to proper version.
