21608 Discussions
Does using register structs affect timing at all (does fitter keep them together?)
Does declaring a register packed structure affect the layout of the registers? (and therefore timing?)
For example,
typedef struct packed {
bit [31:0] ntp_time;
bit [15:0] index;
bit [15:0] value;
bit [15:0] tag;
} _mystruct;
_mystruct table[64];
Does it matter to the fitter that I grouped all these elements together? Or would it be better to separate them instead:
reg [63:0][31:0] ntp_time;
reg [63:0][15:0] index;
reg [63:0][15:0] value;
reg [63:0][15:0] tag;
Using data structures helps me stay organized, but I'm trying to find out if it affects my timing.
How you code it will make no difference. It is the register-register timing that matters - and this wont change when you change the code structure.
