Programmable Devices
21615 Discussions
Driving Ladder DAC
Im trying to drive a resistor ladder DAC from my DE-1 SOC board, despite of my DAC being very accurate im getting somewhat shotty results.
The setup is relatively simple driving the resistors directly from the board. Right now im using plain old 3.3v ttl to drive it.
I was wondering what output standard is best used, and if I can drive Z to it without any troubles?
Kind Regards,
Camper.
Driving 'Z' shouldn't be an issue.
As for the I/O standard - that depends on your design. 3.3V (or 3.0V, 2.5 etc.) TTL or CMOS sounds fine to me and would be what I'd assume to use.
Cheers,
Alex
Awesome! Ill post some images when I get back at it :)
Upon closer inspection I must have botched something using a case statement to drive my logic. So things might not be so gruesome as they appear in the 1st picture :P
EDIT: Nope, its bad, "this" bad then.
https://alteraforum.com/forum/attachment.php?attachmentid=15341&stc=1
Im scratching my head as to what can be causing this issue, does this mean the current gets sunk into ground and only the spikes shows up on the image?
Should it? Should I be wanting a higher impedance from it?
I was hoping to have it right this time, but no luck so far same output from this.
assign GPIO_1[35] = signal[11] ? 1'b1 : 1'bZ;
My question was does this perform the trick of setting the pin to Z directly?
What should the waveform look like?
Do you have passive pullups and/or bus hold function enabled on those I/Os?
Can you set all the outputs to Z, and then only drive one bit (ie, the msb) between Z and 1 (or Z and 0) and capture the waveform?
It shoud look like the 3rd picture in the first series, A somewhat shotty sawtooth wave.
I cant do much "Warning (169133): Can't reserve pin GPIO_0[15] -- pin name is an illegal or unsupported format" So it's the standard setting, it might have an internal pullup enabled. Given the on off hobbyist experience, I don't know much about the board configuration, other than its a bidirectional ttl pin.
https://alteraforum.com/forum/attachment.php?attachmentid=15352&stc=1
I put all the lines to Z, it did show a decent square wave.
https://alteraforum.com/forum/attachment.php?attachmentid=15353&stc=1
When I run the previous arrangement it shows a good squarewave as well.
The problem arises when I connect extra lines to it. It instantly sags to a seemingly nominal level.
It would be interesting to see one line at a time toggle between 0 and Z, or 1 and Z, with all other lines at Z.
You should get reasonably good looking square waves at different frequencies, correct?
What are the values of the resistors in the ladder? If they are too low, will draw too much current, if too high than leakage from pin will change effective value.
The first image is what I would expect to see; each bar is about twice the height of the previous bar.
The other two images appear to have an added bias (ie, base value) compared to the first image.
If as you say the resistor values are 300-600-1200-2400-4800-9600-19200-38400-76800 (like the baud rates...) then if the passive pullup were enabled, typically about 25K, it would really start to affect the values above 9600 rather dramatically, enabling a 25K pullup to H, when your resistor is pulling to L, forming a voltage divider.
Just my suspicion based on your waveforms.
I found the menu responsible for this in the pin planner. According to "this page" (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd01112011_164.html) there is no way around this. Also there is nothing useful in the "pin connection guidelines" for cyclone5 devices..
So is there a way to remedy this?
--- Quote Start ---
--- Quote End ---
That indicates that before a device is configured, and during configuration, the weak pullups will be enabled on the I/O pins. However, you can configure the I/Os to have no weak pullup and no bus hold, so a output that is disabled will only source the leakage current (between -30uA and +30uA per datasheet). BTW 30uA at 3.3V is about 110K effective ohms (minimum; will be higher for lower currents) so even with the weak pullup disabled there will be a pullup/pulldown of something on the order of 110K to 220K or so ohms per I/O.
Picture of the I/O structure:https://alteraforum.com/forum/attachment.php?attachmentid=15362&stc=1
I was looking at another board that may be better at these things. So if I understand correctly even if I get a Max10 device, and it is seemingly better at disabling pullup resistance.
It will not do the job of having it's pins in total isolation?
I had a little test disabling bus hold and weak pull ups, dont know if it looks consistent with having a 110k pullup?
https://alteraforum.com/forum/attachment.php?attachmentid=15364&stc=1
https://alteraforum.com/forum/attachment.php?attachmentid=15365&stc=1
Thanks for the help, the advice you gave me i'm going to check up on that, its awesome!
--- Quote Start ---
Note each bit is driven to either LOW (ie, 0V) or HIGH (ie, 3.3V). 'Z' high impedance value is not required, so I don't understand how/why that originally came into the picture.
--- Quote End ---
I dont really think this board was actually doing the right thing here, it would be cool to have such a state. Maybe only for audio? You are right tho, it doesnt have to be bidirectional.
I had a rail going at 0,05%, using R2R, found the busses on my GPIO connector drive pretty well, the voltages are pretty consistent along the bus. "opportunism I guess".
